samhain6
Nov 09, 2016Aspirant
Need working link to gsm73xxs-6.2.0.6.opr
I'm trying to reflash a bricked Netgear GSM7352Sv1 switch from the serial console using xmodem. After multiple failed attempts and research I've learned that standard .STK firmware images will on...
samhain6
Nov 10, 2016Aspirant
Thanks for the reply, but I've been through those threads and a number of other similar ones. I normally update any and all switches through TFTP, but this switch has no valid operational code, so TFTP and HTTP are not options. I can only boot to the basic boot loader menu: NetGear Boot code...... Version 01.00.09 08-23-2006 Code file code.bin not found in local file system! Operational code CRC is invalid. Options available 1 - Start operational code 2 - Change baud rate 3 - Retrieve event log using XMODEM 4 - Load new operational code using XMODEM 5 - Display operational code vital product data 6 - Update boot code 7 - Delete operational code 8 - Reset the system 9 - Restore configuration to factory defaults (delete config files) Trying to load any version of the .STK firmware files results in: "ERROR: Code image size of 1 bytes is invalid." I believe the only option is to try .OPR firmware which I've read others have had success with.
DanielZhang
Nov 11, 2016NETGEAR Expert
Hi Samhain,
I have sent you a private message.
Please find the *.opr file and operation guide from this private message.
Again, i suggest you to get contact with NETGEAR support.
Use XMODEM to upgrade switch is not recommended.
Anyway, Please don't share those file to anyother people.
Let us know if you have further question.:smileyhappy:
Daniel.
