samhain6
Nov 09, 2016Aspirant
Need working link to gsm73xxs-6.2.0.6.opr
I'm trying to reflash a bricked Netgear GSM7352Sv1 switch from the serial console using xmodem. After multiple failed attempts and research I've learned that standard .STK firmware images will on...
samhain6
Nov 23, 2016Aspirant
Hi, Daniel was able to provide a newer OPR firmware, but it's past the interim gsm73xxs-6.2.0.6 version so it won't fully take (flashes OK, but hangs on boot and hangs on boot code update). If anyone has gsm73xxs-6.2.0.6.opr or earlier please let me know. Thanks
- DaneADec 01, 2016NETGEAR Employee Retired
Hi samhain6,
Kindly click on this link to download the gsm73xxs-6.2.0.6.opr. Hope it helps.
Let us know the results.
DaneA
NETGEAR Community Team
- samhain6Dec 02, 2016AspirantThank you! The firmware flashed using xmodem from the boot prompt menu and the switch is now working.
- DaneADec 04, 2016NETGEAR Employee Retired
Hi samhain6,
You're welcome! :) I'm glad to know that the switch is now working.
Feel free to post your future concerns here in the community.
Cheers,
DaneA
