depinfsocem
Aug 15, 2015Aspirant
Netgear Prosafe M5300 ( lag + NIC Teaming ) Windows Server 2012
Hello , I have a problem in my two stack switch M5300. I have a Lag with two ports 1/0/49(10G) and 2/0/49 (10G) , anda a nic teaming created on Windows Server 2012 . Same times i have a break in my...
Danthem
Aug 15, 2015NETGEAR Employee Retired
Sounds a bit strange - are you running the latest firmware? Try replacing the cables? Should probably call in to the support and have someone look over your settings, but with the information you've provided so far it's hard to say what the issue is. Replacing cables may be enough.
depinfsocem
Aug 16, 2015Aspirant
I replace the cables and nothing... the firmware is 11.0.0.10...
is very strange ..
