wrcrooks
May 18, 2018Follower
NETGEAR ProSAFE XS748T 10Gb SFP+ Compatability
While planning out some network upgrades, I have been told that the 10Gb SFP+ interface on the XS748T-100NES would not communicate properly with a 10Gb SFP+ port on a Dell SonicWall 3600 due to a mis...
LaurentMa
May 18, 2018NETGEAR Expert
Hi wrcrooks
XS748T 10G Smart Managed Pro switch and its 10GBASE-X SFP+ interfaces strictly respect IEEE standards and MSA certifications. Unless your third-party device doesn't, there is no interoperability issue that you should worry about.
What is non-standard here might be the reason why one would want you to stop using industry-standard and industry-leading NETGEAR 10G switch, and change for something else.
I hope this helps!
I hope this helps!
