nicolasd21
Apr 08, 2016Tutor
Probleme de mise a jour GS724T
Bonjour, j'ai fait l'aquisition d'un switch manadgable il y a pas lomgtent et j'ai voulus faire la mise a jour de celuis-ci (GS724Tv3) le probléme c'est que je me suis trompée de mise jours et du...
nicolasd21
Apr 21, 2016Tutor
help
- DaneAApr 21, 2016NETGEAR Employee Retired
Hi nicolasd21,
Welcome to the community! :)
As per Google translate, you have updated the firmware of your GS724Tv3 switch then suddenly you cannot access anything. Is that correct?
DaneA
NETGEAR Community Team- nicolasd21Apr 21, 2016Tutor
bonjour,
oui c'est celas
je me suis trompée de mise a jour et je pas acceder au switch
merci beaucoup de prendre du temps pour mon probleme :smileyhappy:
Hello,
Yes that's right
I was wrong to update and I not access the switch
thank you very much for taking time for my problem :smileyhappy:- DaneAApr 21, 2016NETGEAR Employee Retired
Hi nicolasd21,
Let us isolate the problem. Here are my questions below:
a. Did you perform the firmware update via a wired connection?
b. What is the firmware version you have uploaded to the GS724Tv3 switch?
c. What is the behavior of the LED lights of the GS724Tv4 switch?
d. Did you try to reboot the GS724Tv4 switch then check if will be able to access the web-GUI of it?
e. Have you tried to perform a factory reset on the GS724Tv4 switch?
DaneA
