saima24
Jul 22, 2026Aspirant
Problems with Isolating a VLAN
I’m trying to isolate a laptop with the scenario that there may be a possible malware or infection. Currently my major problem is that we’re not getting our expected results. Our goal is that we have 3 PC’s that we want to restrict traffic so that one of those pcs can communicate to and from the other pc.
Nothing you can reach using a basic VLAN configuration.
What switch model (and firmware version) do you have in mind, or trying?
- saima24Aspirant
We are using the M4250 Series and I'm trying to test and see if we can restrict one pc from reaching the printer on a separate VLAN but allowing the other test pc to be able to get to that printer, and we want to accomplish these results with IP or MAC ACL's
That's a Managed Switch. Have moved this thread to the more appropriate community section.
He smarter approach (instead of fiddling with ACLs only) would be configuring some Private VLAN -> What are private VLANs and how do they work with my managed switch?
- saima24Aspirant
Not sure you got the concept behind Private VLANs right:
- saima24Aspirant
In a way that did help but there's still the problem of whenever i put the port in inbound everything crashes so I think it could be because of the vlan but I did read the article you sent (thank you btw) and searched up how to correctly create a private vlan and added it in but every ping I do is requested timeout and the connection completely goes away as well (I use an ethernet)
