boe
Dec 10, 2025Guide
Can't reset switch to factory defaults
Hello, I've tried the paperclip that usually works for my other switches. Tried 3 seconds, 5 seconds, 8 seconds, 15 seconds, 25 seconds over and over - still doesn't reset. I hooked up a usb...
- Dec 13, 2025
For anyone wondering - I found the solution!!!
schumaku
Dec 11, 2025Guru - Experienced User
boe wrote:I hooked up a usb to mini cable and connected to the mini console port which shows up in device manager as
Silicon labs CP210x USB to uart (Com3)
I try to attach using Com3 in Putty - no response- pressed enter many times
Reads more you have a very basic connectivity issue to the undefined M4300 model switch.
boe wrote:I hooked up my old serial RS232 to USB to an RJ45 adapter - it shows up in device manager as
Aten USB to serial Bridge (COM6)
I try to attach using Com6 in Putty - no response- pressed enter many times
To my knowledge, there is only a USB-C port connecting to a built-in Silicon labs CP210x UART. There is -no- other serial console port on most if not all M4300 switch models. Are you mistaking the OOB (Puit-of-band) GbE port with an RJ45 connector? This is not a serial console.
What your PC does designate as COM3 might be the console port indeed. When you head to https://netgear.com/support/ and locate your model, head to the downloads, there is a "USB Console Driver" - to my knowledge nothing Netgear specific (except of the USB-console-driver.zip file name), these are generic Silicon Labs CP210x drivers.
In case there is no output on the designates USB UART console port after cold power-up the switch, the hardware must be badly broken. Are some LED - and specifically the power LED - light-up when applying power? Just to be on the safe side, re-install this driver on your computer - and reboot the system.
Time to contact Netgear Support via https://my.netgear.com/ to request a hardware exchange, as these switches have lifetime warranty (to the original buyer).
-Kurt.
