boe
Dec 10, 2025Luminary
Can't reset switch to factory defaults
Hello, I've tried the paperclip that usually works for my other switches. Tried 3 seconds, 5 seconds, 8 seconds, 15 seconds, 25 seconds over and over - still doesn't reset. I hooked up a usb...
- Dec 13, 2025
For anyone wondering - I found the solution!!!
schumaku
Dec 11, 2025Guru - Experienced User
Originally, the Reset button on the front was just a reset:
- Up to 5 seconds initiates a reset (soft restart)
Starting from firmware v12.0.6.6, some function overload is in place:
- 2...5 seconds initiates a reset (soft restart)
- 5 seconds or longer does a factory reset
boe
Dec 11, 2025Luminary
Thanks - as I mentioned the reset it not working. I have a dozen of these switches. I can tell when the reset is pressed in and I can count past 5. It will not reset - there are many web pages of people having the same issue - this is not an unknown issue. Tech support just wants to sell you warranty so calling them isn't very helpful.
- schumakuDec 11, 2025Guru - Experienced User
Permitting, the serial console would be workable, there would be alternate ways doing a factory reset.
This is the formal way - permitting the serial console remains workable, and the switch isn't completely dead:
M4300 Resetting to factory default using the boot menu/
These managed switches are coming with a limited lifetime warranty for the original buyer.
Talking of Netgear M4300 Managed Switches? Links and references please...
This is for consumer devices. Have you mentioned you talk of a managed M4300 Series switch model?
In case your undefined M4300 switch model is properly registered to your account, head to https://my.netgear.com/ click on the registered device, and follow the [Request Hardware Support] process please.
