boe
Dec 10, 2025Guide
Can't reset switch to factory defaults
Hello, I've tried the paperclip that usually works for my other switches. Tried 3 seconds, 5 seconds, 8 seconds, 15 seconds, 25 seconds over and over - still doesn't reset. I hooked up a usb...
- Dec 13, 2025
For anyone wondering - I found the solution!!!
boe
Dec 11, 2025Guide
Thanks! - I got there but was unable to reset it - it kept asking for the admin username and password and blank as the PW did not work. I ended up at the point of just being stuck at the M4300R2 prompt as I must have cleared the entire config.
I've set up a tftp on my PC
I have the firmware file loaded as far as I can tell -- not sure the next step
schumaku
Dec 12, 2025Guru - Experienced User
boe wrote:Thanks! - I got there but was unable to reset it - it kept asking for the admin username and password and blank as the PW did not work. I ended up at the point of just being stuck at the M4300R2 prompt as I must have cleared the entire config.
Why ever. Strictly following the https://kb.netgear.com/30329/M4300-Resetting-to-factory-default-the-boot-menu would have saved a lot of time and effort. It's not difficult at all - just do it:
As you have ended at the m4300r2> prompt - assuming your tftp server is reachable - on the switch console, type the following command on the console:
copy tftp://<tftp server IP address><image name> image1 or image2
The switch will ask to confirm with input data displayed. Hit enter if all parameters look correct. The file transfer process should take about two minutes, then the new firmware will be checked for possible corruption, if all checked out, it will report firmware successfully upgraded.
“<tftp server IP address>” is the IP address where the TFTP server is running. The “<image name>” is the new firmware to upgrade to, and make sure the file is stored in the TFTP root directory. Select either to upgrade the image1 or image2.
This copies the switch image from the tftp server into the image1 resp. the image2 section on the flash.
To use CLI to change the image to be used in the next reboot, type the following command:
boot system <image1 or image2>
And issue the following command to reboot:
reload
No idea if this will recover your switch to a workable condition. I hope you have not destroyed the startup menu code with these experiments.
If not ... I'm out at that point, because anything else is beyond my pure community member competence as I'm not Netgear here.
- boeDec 12, 2025Guide
Thanks this is the only option I have - that menu doesn't come up
- boeDec 13, 2025Guide
Thanks so very much for hanging in on this situation I was getting way too frustrated but you were kind enough to stick in there!
I'm 100% even though the latest firmware has a bug and brings you to the wrong login page.
It tries to bring you here (substitute your own IP)
https://10.100.100.128:49152/v1/base/cheetah_login.html - goes nowhere
It should be
http://10.100.100.128:49151/v1/base/cheetah_login.html
- schumakuDec 13, 2025Guru - Experienced User
Once https is enabled, https://[IP]:49152/ ... no, this does no longer exists, the landing page it's now on https://[IP]:4443/ http://[IP]:49151/ is the default without https, once https is activated again, https://[IP]:49152/ will return.
Somewhere back in 2023, Netgear has added an additional Web UI for different usage scope:
AV GUI = 49151
Main GUI = 80
http://[IP] (so port 80 by browser default) does redirect to a landing page on https://[IP]:4443
It's possible a default installed M4300 without any default config might be lead to the wrong page - this might be the price for the added AV GUI....
Keep in mind you have to use the Main GUI for the full IT network admin Web UI - not the AV GUI.
I'm happy you located the full recovery procedure. Have slightly modded that page, changing from M3400 to M4300 for future reference.
