vabulldog
Jul 29, 2022Aspirant
VLAN/ DCHP help
Hello, 'I have a new GS752TPv2 switch. I am hooked up to my Fios router. I was able to change my switch's IP address and wanted to play around with VLANS. I added 2 VLANS (50 & 90). My local network...
JeraldM
Jul 29, 2022NETGEAR Employee Retired
Hi vabulldog,
That is right, the IP range will come from the router.
Usually, you tag ports if they are connected to another switch or any device that recognizes 802.1Q tags where you want multiple VLANs to pass through it and then untag ports if these are end devices such as computers, printers, and such.
JeraldM
NETGEAR Community Team
vabulldog
I fired up my desktop and put it on port #47 on VLAN 90. I gave it a static IP address of 192.168.90.69 subnet of 255.255.255.0 and a default gateway of 192.168.9.1. It can ping and access the switch GUI but I am getting a no internet access globe icon and cannot access the internet.
Also, when I go to the default VLAN in VLAN membership and try to leave port #47 blank I get an error that says "Error! Management access will be lost on MGMT VLAN configuration" Is that basically telling me that if I remove access to that port from the default VLAN I won't be able to access the GUI?
- schumakuJul 29, 2022Guru - Experienced User
Before people are going crazy here:
Does this router support the configuration of multiple networks, IP subnetworks, and DHCP for each, e.g. on a per port or VLAN level?
I fear this is where many first adventures end. Most consumer routers, ISP supplied end-user routers, and so on don't support this.
Last but not least: This GS752TPv2 isn't a managed switch model.
- schumakuJul 30, 2022Guru - Experienced User
For the systems connecting to the switch, eg. on port 47, intended to work in a subnet different from 192.168.1.1/24, so e.g. on the VLAN 90 and 192.168.90.x addresses, you might want to
- remove the [U]ntagged membership from VLAN 1
- add a [U]ntagged membership for the VLAN 90, and define these ports for PVID 90
This will bring the system plugged to the correct VLAN on what is named sometimes as an access port.
Next, for the normal subnet 192.168.1.x/24, you need to define a static route on your Internet router, adding a route to the 192.168.90.x/24 subnet pointing to the switch LAN IP. Otherwise, the routed traffic can't flow in both directions.
