daveoneal
Sep 20, 2016Aspirant
Service Port routable on managed switch ?
Is the Service Port or Out of Band port connected via ethernet routable?
I have our correct subnet and default gateway setup and can't ping past the default gateway (which is a cisco router).
I can ping the default gateway.
I can also access the switch if I am on the local LAN.
I can't access the switch if I'm on another subnet. The cisco is configured right.
I could use a port on the main switch and it works, but I thought the whole point of the out of band interface is to segregate traffic for management.
- DaneANETGEAR Employee Retired
Hi daveoneal,
Welcome to the community! :)
What I know about Out-of-Band connectivity is that you will need to use the console port to connect the switch to a terminal desktop system running terminal emulation software.
What is the model of the NETGEAR switch you have?
DaneA
NETGEAR Community Team
Hi daveoneal,
I just want to follow-up on this.
DaneA
- daveonealAspirant
No, there are at least two out of band ports. One is USB to serial in which you use terminal emulation.
But another is RJ45 ethernet with a default IP address of 169.254.101.100. We had set that IP address to an internal one with the correct gateway. We can address that IP address from on the same LAN segment. We can't access that IP address if we are one hop away. That doesn't make sense because the IP routing looks correct.
The out of band port is set to 10.10.1.120
I can access every other device in the 10.10.1.x range from my subnet (172.16.3.x) but not the netgear
The netgear has the same default route as every other devce on 10.10.1.x
So there must be something special about the out of band port, but I can find nothing in the docs.
Hi daveoneal,
It would be best if you post a screenshot or image of your detailed network setup. Also, what is the model of the NETGEAR switch you are referring to?
DaneA
- Retired_Member
Hi daveoneal,
I have tested the scenario same as you. And the ServicePort can be routable if config gateway in ServicePort.
Maybe it's helpful for you.
[Test topology]:
PC1------(port1)Switch1(port2)-------(ServicePort)DUT(port1)--------(port1)Switch2(port2)--------PC2
[Configuration]:
For DUT:
- SevicePort IP is 200.1.1.2/24, gateway is 200.1.1.1
serviceport protocol none
serviceport ip 200.1.1.2 255.255.255.0 200.1.1.1
- Port1 IP is 100.1.1.1/24, Create one default route, next-hop is 100.1.1.2
interface 1/0/1
routing
ip address 100.1.1.1 255.255.255.0
exit
ip route default 100.1.1.2
For Switch1:
- Port2 IP is 200.1.1.1/24
interface 1/0/2
routing
ip address 200.1.1.1 255.255.255.0
exit
- Port1 IP is 201.1.1.1/24
interface 1/0/1
routing
ip address 201.1.1.1 255.255.255.0
exit
For Switch2:
interface 1/0/1
routing
exit
- Port2 IP is 101.1.1.1/24
interface 1/0/2
routing
ip address 101.1.1.1 255.255.255.0
exit
For PC1:
Set IP is 201.1.1.2/24, gateway is 201.1.1.1
For PC2:
Set IP is 101.1.1.2/24, gateway is 101.1.1.1
[Test Result]:
From PC1: ping 201.1.1.1/200.1.1.1/200.1.1.2 ok, so PC1 can reach DUT ServicePort success
From PC2: ping 101.1.1.1/100.1.1.1/100.1.1.2 ok
