oikjn
Aug 01, 2019Tutor
Switch host name registered DNS name is always blank
firmware v11.0.0.31 Is there any way to get the switch to register its name with DNS/DHCP? I tried using both static IP configurations and DHCP, but the DNS won't register and the DHCP lease (on...
Retired_Member
Aug 02, 2019Hi oikjn
On Netgear switch, "system name" is designed to be used as device name by uPnP/NSDP/SNMP protocol discovery, not used for DNS domain or FQDN, thanks for your understand.
- schumakuAug 02, 2019Guru - Experienced User
Re-iterating Retired_Member information a little bit ... DHCP and DNS updates are two complete different and independent features. Before Windows Server 2003 (if I have my old grey cells right), there were ways to configure a DHCP server to dynamically update DNS with the name provided along with the DHCP request. Starting from then some secure DNS update methods were implemented, e.g. on Windows systems, allowing to dynamically update the DNS server with the name and IP. Such a feature might be nice for mobile clients like Windows systems on notebooks which connect to different sites, at different locations of an organisation. Most embedded systems, including routers and switches, don't have such a DNS updater (e.g. per RFC3008) on board.
- oikjnAug 02, 2019Tutor
schumaku , your memory does serve you correctly. The DHCP server will securely update an Active directory integrated DNS server to match device names with IP addresses the DHCP server issues. The "issue" is that for whatever reason, the netgear switches do not provide a name to the DHCP server and this IS unusual. Pretty much every other device I have like switches from other companies or Access points or pretty much everything at least provide the DHCP server with a device name.
Retired_Member Why would you NOT use the system name for device registration with DNS/DHCP? every other device manufacturer I'm aware of provides does this.and it seems trivial and more like this is simply an oversight for some reason.
oikjn wrote:The "issue" is that for whatever reason, the netgear switches do not provide a name to the DHCP server and this IS unusual. Pretty much every other device I have like switches from other companies or Access points or pretty much everything at least provide the DHCP server with a device name.
Ok, you are certainly right - must admit that we configure the Netgear Managed class switches to static IP configs by VLAN and only manage static DCHP reservations for fall-back and I've never cared about the DNS registration (they are registered in DNS manually anyway).
oikjn wrote:Why would you NOT use the system name for device registration with DNS/DHCP? every other device manufacturer I'm aware of provides does this.and it seems trivial and more like this is simply an oversight for some reason.
The Smart Managed Pro and Smart Managed Plus do supply the configured host names. Let's see what LaurentMa can enhance the specs svp.
