auniquename's avatar
auniquename
traverse multiple vlans with a device that has no gateway
I have vlan 10, 20, 30 and 40 configured on 4 switches
I have a device(let's call it "BBB") that does not have a default gateway (it's configured w/another route for remote access)
Presently I can access any device on the same vlan (it's cabled to port 2 w/vlan 10) on the same switch via BBB
The switch has a trunked port allowing all vlans, the switch also has vlans built w/an ip address 4th octet ending in 100
The default gateway points to a fortinet
But I can't access any other device in another vlan on another switch using BBB
The 4 switches are all trunked together allowing all vlans (it's inline  switch A <> switch B <> switch C <> switch D)
I've replaced BBB w/a laptop configured w/a default gateway and I can ping all devices on all vlans on all switches.
but the laptop w/o a default gateway, I can only ping devices on that switch (switch A) and nowhere else
any ideas?
  • none of the answers are relevant, the topic is a device without a gateway address, needs to traverse more than 1 vlan, can this be done with your switches? if yes, how to configure?
    • Retired_Member's avatar
      Retired_Member
      auniquename
      Of course support.
      You have to add the uplink port(connect between two switch) to VLANs with tagged mode, then the port will traverse these VLANs traffic.
    Retired_Member
    Hi auniquename
    Welcome to the community!
    According your description, it's work as design.
    If host want to ping same VLAN device, it's no need forwarding by gateway, just running Layer-2 forwarding(mac table-based).
    If host want to ping different VLAN device, it's need forwarding by gateway, need running Layer-3 forwarding(route table-based).
    So you must set default gateway for device, then it can ping both same VLAN devcie and defferent VLAN device.
    Hope it helps!
    EricZ
    NETGEAR employee
    • auniquename's avatar
      auniquename
      does the switch have intervlan routing capability?
      GS752TPS
      • JohnC_V's avatar
        JohnC_V
        NETGEAR Employee Retired
        auniquename,
        GS752TPS does not support intervlan routing capability. You might need to check intervlan routing on your router / firewall as it is the one that handles your VLAN gateways.
        Hope this helps.
      auniquename
      but you're not reviewing the question well enough.
      The device (BBB) already has a default gateway which points to the WAN.
      Device BBB is used for remote access, and it does not have a 2nd default gateway.
      again no default gateway can be configured on the LAN NIC
      On device BBB connection to the LAN via switch, it can only reach devices on that switch, in that vlan.
      I need to be able to ping another device on another vlan which resides on another switch.
      I hope this make it a bit clearer
      Device BBB <-> switch A vlan A (all devices ping) <-> switch B vlan B (unable to reach any device)
ProSupport for Business
