jtpubcon
Aug 16, 2013Novice
Upgrade GSM7352Sv2 To Firmware 10.0.0.31 Fails
I am trying to upgrade a stack of two GSM7352Sv2 switches to 10.0.0.31, so that I can add a M5300 to the stack. The switches crash on load when running the 10. firmware. I am basically trying to do one switch at a time, so here are the steps I have taken.
1) Uploaded the new firmware to available archive image via HTTP app
2) Remove the stack card from the master switch
3) Reset to factory default from the CLI Boot Menu
4) Switched to back up (10.) image via CLI Boot Menu
5) Update Boot Code via CLI Boot Menu
6) Reset switch
Here is a snippet from the CLI Boot Sequence. Has anyone successfully done this?
Boot Code 01.00.35
CPU Card ID: 0x508541
Boot Menu 01.00.35
Select an option. If no selection in 3 seconds then
operational code will start.
1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):
Operational Code Date: Fri Feb 22 20:01:38 2013
Uncompressing.....
Bulk Class Driver Successfully Initialized
Adding 0 symbols for standalone.
Instantiating /download as rawFs, device = 0x20001
Formatting /download for DOSFS
Formatting...OK.
<10> JAN 01 00:00:25 0.0.0.0-1 General[268434704]: bootos.c(225) 1 %% Event(0xaaaaaaaa)
Instantiating RamCP: as rawFs, device = 0x30001
Formatting RamCP: for DOSFS
Formatting...OK.
(Unit 1)>*** End-of-block heap corruption found
0xb2d38c0 (ipMapProcessingTask): memPartFree: invalid block 0xea80400 in partition 0x38f6028
0xd0f8820 (DHCPv6 Server Processing Task): memPartFree: invalid block 0xea80400 in partition 0x38f6028
Dumping heap from 0x0ea6b2d0 to 0x0ea6b750. Block being freed = 0x0ea6b350
Corrupt block allocated at time 45, from dhcps_migrate.c line 239
0ea6b2d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b2e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b2f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b320: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b330: 00 00 00 00 1c 79 c9 e0 b7 b7 b7 b7 00 00 00 00 .....y..........
0ea6b340: 00 00 1b 80 00 01 50 b1 03 8f 60 28 03 b1 7e e8 ......P...`(..~.
0ea6b350: a7 a7 a7 a7 00 01 50 60 0b 07 16 60 00 00 00 01 ......P`...`....
0ea6b360: 00 00 00 34 00 00 00 00 0e a5 66 a0 0e a5 5e 20 ...4......f...^
0ea6b370: 64 68 63 70 73 5f 6d 69 67 72 61 74 65 2e 63 00 dhcps_migrate.c.
0ea6b380: 00 00 00 ef 00 00 00 2d 64 68 63 70 73 4c 65 61 .......-dhcpsLea
0ea6b390: 73 65 73 2e 63 66 67 00 00 00 00 00 00 00 00 00 ses.cfg.........
0ea6b3a0: 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 34 ...............4
0ea6b3b0: 00 00 00 01 00 05 40 60 00 00 00 00 00 00 00 00 ......@`........
0ea6b3c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b3d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b3e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b3f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b410: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b420: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b430: 00 00 00 00 00 00 000x 4865a10 (bcmCNTR.10): memPartFree: invalid block 00xea80400 in partition 0x38f60280
0x42cc090 (bcmCNTR.00): memPartFree : invalid block 0x0ea80400 in partition 00x38f6028
0ea6b440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b460: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b470: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b480: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b490: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b4a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b4b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b4c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b4d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b4e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b4f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b520: 00 00 00 00 00 00 00 2d 00 00 00 00 00 00 00 00 .......-........
0ea6b530: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b540: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b550: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b560: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b570: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b580: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b590: 00 00 00 00 00 00 00 00 00 00 00 00 000x 4865a10 (bcmCNTR.10): memPartFree: invalid block 00xea80400 in partition 0x38f60280
0ea6b5a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b5b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b5c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b5d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b5e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b5f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b620: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b630: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b640: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b650: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b660: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b670: 00 00 00 00 00 00 00 2d 00 00 00 00 00 00 00 00 .......-........
0ea6b680: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b690: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b6a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b6b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b6c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b6d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b6e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b6f0: 00 00 00 00 00 00 00 00 00 00 00 00 000x 4865a10 (bcmCNTR.10): memPartFree: invalid block 00xea80400 in partition 0x38f60280
0ea6b700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b710: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b720: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b730: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0ea6b740: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x4865a10 (bcmCNTR.1): memPartFree: invalid block 0xea80400 in partition 0x38f6028
0x42cc090 (bcmCNTR.0): memPartFree: invalid block 0xea80400 in partition 0x38f6028
0xb071660 (DHCP Server Processing Task): memPartFree: invalid block 0xea80400 in partition 0x38f6028
- jtpubconNoviceFYI, the switch is starting with 8.0.0.25.
- Marto731AspirantJPubcon,
Excuse me for replying 5 months after your post. This may help others.
You have to go to the last version on V8, specifically V8.0.3.34, before you can go to the first variant of V10.
There is a different boot code between V8.0.2.25 and V8.0.3.34
http://support.netgear.com/product/GSM7328Sv2
There is a detailed Word doc in release notes of V8.0.3.34,
which you will need to study closely.
Extract this from the code Zip.
http://downloadcenter.netgear.com/en/product/GSM7328Sv2
Regards Marto.
