AndrewCole
Mar 26, 2026Follower
Vlan Combine when Partition Walls controlled QSC
Looking for info/ help. We are using a M4250-26G4F-POE+ with a QSC core to Combine 2/3 meeting room together. We are using a Huddly Crew Cameras (poe) . I'm looking to Combine 3 Different Vlans...
BrettD
Apr 02, 2026NETGEAR Employee
If the Huddly cameras are using unicast then cross VLAN should work, however with Multicast - they will need to be in the same VLAN as the PC. Theoretically you can use PIM, but I would avoid at all costs. Just put them into one VLAN.
