Arnaud_D
Oct 24, 2016Aspirant
Vlan routing M5300 / GS724T
Hello, I'm planning to split my network in multiples Vlans. I want to use my M5300 to do the vlan routing but i encounter an issue, i can't ping my vlan interface. I'm doing test on M5300 (11...
- Oct 25, 2016
Hi,Arnaud_D
Welcome to NETGEAR community!
I have read your post , and I think there somethig settings below may be helpfully to you:
1.Disable vlan routing on GS724T. GS724T is a smart switch which is mainly process L2 traffic,and in your topo it also not
necessary for GS724T to process routing.
2.I saw in your description there is no ip address for vlan 1, so I guess may be your M5300 connect to firewall through a
l2 port. Suggest to and a ip adderss which is at same subnet of your firewall address.
3.Additionally, you need t to check in you firewall if there are routes to 192.168.11.1/255.255.255.248 and 192.168.15.1/255.255.255.128
If no,please add.
hope it helps
Carl_z
Netgear Employee
DaneA
Oct 24, 2016NETGEAR Employee Retired
Hi Arnaud_D,
Welcome to the community! :)
Let me share the article below and kindly use it as a guide:
VLAN Routing on NETGEAR Smart Switches
Hope it helps.
DaneA
NETGEAR Community Team
