tantony
Oct 17, 2018Luminary
XS716T, see attached devices
I have a XS716T switch. I know the IP address of this switch, and I'm logged in. I have an access point connected to this switch, but I don't know what the IP is. How can I find the IP of the acce...
- Oct 18, 2018
tantony wrote:
It's a Ubiquiti UniFi AC Pro
Not much you can do - even of you have the IP address. These are strictly controller managed devices, either bound to a local controller, or to a cloud controller. Ubiquity does provide some discovery tools and Apps. But then, you still won't be able access that AP easily.
tantony
I can see the AP's MAC address on the address table on the switch, but no ip info. Is there a way to ping a MAC to get IP?
- Nodism1125Oct 17, 2018NETGEAR ExpertInstall an IP scanner to detects IP address and MAC address. The XS716T switch detects the Learned MAC address only.
- tantonyOct 17, 2018Luminary
ok, which range do I scan?
0.0.0.0. - 255.255.255.255?
Check the IP range of your router.
Example: starting IP: 192.198.1.2 and ending IP: 192.168.1.254
