sos100
May 24, 2016Aspirant
Adding a new GS724T switch via SFP Fibre connection
Hi -
This is one of those "double checking I have this correct" queries. I have reviewed the other answers on the topic I can find in here, which have been helpful.
We have a single Netgear ProSafe Smart Switch GS724Tv4 (24 ports). We're out of ports, and now need to expand. My plan is to buy another one, and connect them using the SFP LC GBIC Fibre connection (so, buy two transceivers, one for each switch) and a suitable fibre cable to connect the two in the rack.
My question is : is that correct? Any issues, guidance or other gotchas that we should be aware of as we plan this?
Thanks, Sean
Hi sos100,
Welcome to the community! :)
What you are planning to do is correct. Both the AGM731F and the AGM732F are the modules that are compatible with the GS724Tv4. Refer to the table below:
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi sos100,
DaneA
- JohnRoNETGEAR Employee Retired
Hello sos100,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- sos100Aspirant
Thanks - have done that now! Cheers, Sean
