ddejarnett
Mar 05, 2019Tutor
Can't Access Admin Interface over LAG on XS716E
I have a XS716E 16 Port 10-Gigabit Ethernet Smart Managed Plus Switch with a 6 port LAG configured that is connected to a Cisco trunk. From a node on the Cisco, I can't access the admin interface of the Netgear, but when I plug directly into the Netgear, it works. The ports in my LAG are configured with all VLANs IDs. The other ports on my switch are configured with the same VLAN as my main network.
Can anyone tell me why I can't access the admin interface over the LAG?
David
Have no more XS708Ev1/XS708Ev2XS716E in operation. Vaguley remember having had the very same problem on one or some of these models initially, however it was fixed with some firmware update later on. Must admit never had that many ports in a LAG, but up to two resp. four ports in a static LAG.
Is the firmware updated to the current version from https://www.netgear.com/support/product/XS716E#download ?
Communication on the VLAN trunk and the ports associated to the VLANs configured does essentially work - just the admin Web UI is causing issues?
Aware the XS716E does only support static LAG, no IEEE 802.3ad Dynamic link aggregation, 802.3ad with LACP) - is the Cisco configured accordingly?
Traffic gets passed perfectly over the trunk/LAG. (on all VLANs) I just can't connect into the web ui without being on a device connected directly to that switch.
