Tomasz_FLX
Nov 22, 2019Aspirant
Factory reset doesnt work
Hello, I have a switch configured with vlan and other settings, but I don't have a password. I want to restore the default settings. I performed the procedure in accordance with the factory reset in...
- Nov 25, 2019
Hi Tomasz_FLX,
Is your switch GS728TS/GGS728TPS/GS752TS ?
i think to have two buttons on the switch panel: "Reset" and "Factory default"
You can hold "Factory default" button greater than 5 seconds, the switch will be initialized.
BTW: if there was not "Factory default" button on switch panel, Usually you can hold "Reset" button greater than 10 seconds, the switch will also be initialized.
Thank you
schumaku
Nov 22, 2019Guru - Experienced User
Is this in a stacking configuration?
- Tomasz_FLXNov 22, 2019Aspirant
No. This is a single switch.
