Tomasz_FLX
Nov 22, 2019Aspirant
Factory reset doesnt work
Hello, I have a switch configured with vlan and other settings, but I don't have a password. I want to restore the default settings. I performed the procedure in accordance with the factory reset in...
- Nov 25, 2019
Hi Tomasz_FLX,
Is your switch GS728TS/GGS728TPS/GS752TS ?
i think to have two buttons on the switch panel: "Reset" and "Factory default"
You can hold "Factory default" button greater than 5 seconds, the switch will be initialized.
BTW: if there was not "Factory default" button on switch panel, Usually you can hold "Reset" button greater than 10 seconds, the switch will also be initialized.
Thank you
