Tomasz_FLX
Nov 22, 2019Aspirant
Factory reset doesnt work
Hello, I have a switch configured with vlan and other settings, but I don't have a password. I want to restore the default settings. I performed the procedure in accordance with the factory reset in...
- Nov 25, 2019
Hi Tomasz_FLX,
Is your switch GS728TS/GGS728TPS/GS752TS ?
i think to have two buttons on the switch panel: "Reset" and "Factory default"
You can hold "Factory default" button greater than 5 seconds, the switch will be initialized.
BTW: if there was not "Factory default" button on switch panel, Usually you can hold "Reset" button greater than 10 seconds, the switch will also be initialized.
Thank you
schumaku
Nov 22, 2019Guru - Experienced User
Tomasz_FLX wrote:I performed the procedure in accordance with the factory reset instructions but it did not work.
Which ones?
Used the Factory Default Reset button (not the Reset button) on this switch?
Tomasz_FLX
Nov 24, 2019Aspirant
Yes, Factory Default Reset.
I held 2 seconds The LEDs went off and I released the button. After about 1 minute, all the LEDs were amber and it lasted about 5 minutes, then turned the power off and on. Switch remained old settings.
- kevin_hongNov 25, 2019Apprentice
Hi Tomasz_FLX,
Thank you
