Skia
Jun 18, 2017Aspirant
False Advertising/False Information regarding FS728TP Smart Switch
That or the guy I called is lying to me. I purchased this SW with under the pretense based on the manual that it would offer QOS Bandwidth limiting. The manual here clearly states that it can ...
JohnC_V
Jun 22, 2017NETGEAR Employee Retired
Hi Skia,
Welcome to the community!
As I checked the image that you attached, you were only at the Smart Control center on which this application shows all the connected smart switches to your network. You can also change the IP and other parameters on this application but not all of it. You need to login to the admin page of the switch for you to configure the QOS/Bandwidth limiting for this switch. To login, Select the switch then click Web Browser Access.
Please check the reference manual on page 2-1.
Skia
Jun 22, 2017Aspirant
You are only looking at one of my three monitors.
If you look at all the images you should be able to understand what I am saying.
