gmangi's avatar
gmangi
Guide
Jan 31, 2021
False advertising
I purchased a brand new c7000 for $170 through amazon. Upon recieving the NEW router and modem, when attempting to register the device, it was already registered under another use! They had to verify I had actually purchased the device and I had to send a copy of my order receipt. Even further when I finally got the "New" device under my account, I couldn't get past the previous owner's security questions that had already been set up! Definitely no way it wasn't used. Spent over 3 hours on the phone with netgear with being put on hold for 30 minutes twice. I even had to call a second time after the first person I first spoke with said they would call back if we got disconnected. They never did. Then when they said they were going to escalalte the issue, they wouldn't get back to me for 3 hours. Guess what? Still no call! Everything about this experience is so unethical and false advertizing.
  • michaelkenward's avatar
    michaelkenward
    This happens regularly and has nothing to do with second-hand stuff. It seems to be something that happens at Amazon. Things seem to leave the warehouse with registration issues.
    For human intervention, try this:
    NETGEAR Product Registration FAQ | Answer | NETGEAR Support
    But you shouldn't need it.
    There is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
    If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
    This bit is baffling:
    You don't need to spend a nanosecond on line to find the answer.
    Even if they exist, a factory reset will instantly eliminate any old password and security questions.
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    Any support person would know that instantly. It is the first thing anyone will advise.
    For more help, visit the support pages:
    Support | NETGEAR
    Check the section in the manual Factory Settings.
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
    • schumaku's avatar
      schumaku
      One problem with Netgear's registration process is that anybody can randomly type and mistype serial numbers, for example to gain free support access beyond of the 90 days free. There is no checksum or the like in the serial number.
      Another interesting point: Considering Netgear does not publish telephone support numbers, I wonder where the gmangi  called to.
      Excellent and comprehensive reply michaelkenward !
    • gmangi's avatar
      gmangi
      Guide
      michaelkenward
      1. Amazon claims it is a netgear problem and they don’t open packages direct from their suppliers
      2. As I said, netgear confirmed that it was registered to another user previously and yes, I had no option to set my own security questions. It seems with these 2 factors that the only logical conclusion is that I am in fact not the first user and I bought this new.
      3. I did a factory reset, or hit the manual reset button on the router if that’s what you’re referring to as a hard reset, and it did not resolve the issue.
      It was either netgear or Amazon, but someone screwed up, an Amazon says it wasn’t them, so???
      • schumaku's avatar
        schumaku
        gmangi wrote:
        michaelkenward
        You fighting a ghost. Far to many complete factory new (and factory reset devices) Netgear products ask for answers to security questions even if there was never set one after some retries of the default password..
