Peter_Che
Sep 26, 2025Guide
GS108TV2 hard reset
Hi! Is there a way to hard reset a Netgear GS108TV2?
Thanks
there should be a hard reset button on the front of it. The guide goes over it.
https://www.downloads.netgear.com/files/GDC/GS108Tv2/GS108Tv2_HIG_EN.pdf
Yes, thank you
Glad you found it. I take it that it worked?
I apologize, I found a button Factory Defaults !!
There is no button Factory Defaults
What happens when you push and hold the button while powered on?
Do the lights blink? Anything change?
This button doesn't help and doesn't respond.
