Witzker
Mar 24, 2023Aspirant
GS108Tv2 Switch not discovered but IP shown in SmartControllCenter
Hi,
Im totaly new with this switch stuff
I wanted to update firmware for my Netgear GS108Tv2 Switch
but I cannot discover the switch with SmartControllCenter
I can login with the IP
and also the IP of the adapter is shown in CotrolCenter
but when I press discover nothing is found?
when I goto firmware nothing is there!?
What have I done wrong??
Pls help a newbie
many THX
1 Reply
Witzker wrote:
Hi,
Most people here are in the same boat.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
