LW100
Dec 11, 2024Aspirant
GS308Ev4 - Cant login to it via browser on mac
All, looking for some help, I have a GS308Ev4, which I have connected to a SKY Q router... FW version 1.0.0.8... and using the Network Disc tool, it finds the switch on default IP of 192.168.0.209. All good so far... however while I can access the admin console via my iPhone on wifi, I cannot access the admin console from my wired mac. I have tried both Chrome and Safari, and I get nothing..... browser seems to try to connect, but it doesnt. MAC is on some lan, I can ping the switch, browser simply won't connect. Any ideas, or has anyone experienced this ?
Thanks
1 Reply
- ErwinLNETGEAR Moderator
Hello LW100
And welcome to the NETGEAR Community! 🙂
Is it possible for you to try a Windows based computer just to check if you will be able to access the switch from there? Try also making a static IP on your computer with the same range of the default IP of the device and see if you will be able to access it. Just be reminded that you have to be directly connected to the device.
Have a lovely day,
Erwin
Netgear Team
