pbrady's avatar
pbrady
GS724TS - Javascript Errors
AHi all,
I have 3 switches configure in a stack. I've previously had no problems until one day when I tried to log in to manage the device, and navigated to Switching -> VLAN -> Advanced -> VLAN Membership nothing comes up in the actual tagging tagging dialogue.
If you select a new VLAN ID, and look to the browser console the following error trace appears:
Uncaught TypeError: Cannot read property 'selectNodes' of null
    at theClass.BaseTable.serializeInnerNodes (BaseTable.js:4)
    at theClass.Membership.display (MemberShip.js:407)
    at theClass.Membership.complete_get (MemberShip.js:706)
    at CallBackObject.ReadyStateChange (CoreInfrastructure.js:6)
    at XMLHttpRequest.XmlHttp.onreadystatechange (CoreInfrastructure.js:6)
BaseTable.serializeInnerNodes	@	BaseTable.js:4
Membership.display	@	MemberShip.js:407
Membership.complete_get	@	MemberShip.js:706
CallBackObject.ReadyStateChange	@	CoreInfrastructure.js:6
XmlHttp.onreadystatechange	@	CoreInfrastructure.js:6
XMLHttpRequest.send (async)
CallBackObject.DoCallBack	@	CoreInfrastructure.js:6
BaseTable.get	@	BaseTable.js:4
GuiObject.superclass	@	CoreInfrastructure.js:4
Membership.get	@	MemberShip.js:141
onchange	@	home.htm:1
ListPicker._handleMouseUp
I reliase I'm using an older model however I really need this to work. I have tried with multiple different browsers and multiple different computers, all produce the same results.
Thanks
  • If on Windows, try IE! You might have to use the compatibility mode.
  • schumaku's avatar
    schumaku
    • pbrady's avatar
      pbrady
      You know what schumaku I thought I had covered every base but you've done it! Thanks so much.
      In the past I've been running older versions of Firefox (atm it's 37.0) to get access but even that has failed me lately, maybe I need an older version. Really appreciate your help!
      • schumaku's avatar
        schumaku
        Legacy business applications are the key reason IE11 with all it's backward compatibility modes is still a core app on Windows 10. 8-)
ProSupport for Business
