indebridge
Feb 06, 2018Aspirant
GS728TP Enable/Disable Port on a Schedule
Can I set up the switch to automatically enable and a specific port on a schedule? For example, enable port at 0700, disable port at 1200, enable port at 1500, and disable port at 2000. I'm looking ...
- Feb 07, 2018
Hi indebridge,
Welcome to our community!
The switches doesn't have the capability to enable / disable the ports by schedule. If you want, you may suggest or recommend it in our Ideas Exchange for Business board. NETGEAR is open for any recommendations.
JohnC_V
Feb 07, 2018NETGEAR Employee Retired
Hi indebridge,
indebridge
Feb 08, 2018Aspirant
Thanks for the reply,
I guess I'll just pick up the cheapest 4-5 port switch I can find and set up the power supply for it on a outlet timer like you'd use on christmas lights. It might not be as refined as I'd like, but the simplicity and reliability will be hard to beat.
- JohnC_VFeb 08, 2018NETGEAR Employee Retired
I agree with you on that. May I know what is your purpose of having the ports to be scheduled?
- indebridgeFeb 11, 2018Aspirant
So bear with me here, I’m very new to all of this. I have two networks running side by side. The first is configured to run our IP phones, clocks, and access points. The second contains the satellite internet and the network drops for the primary computers. In order to provide internet access via WiFi for personal use, we have the two connected. However, since our internet is satellite based, it is easily worked at capacity by the first network causing the primary computers to lose all productivity. The secondary network is locked down by the impossible to get a hold of home office, so I can’t change anything there, our work around is to disconnect the two networks during the times of heavy primary computer use. I was hoping to be able to put this schedule into the switch so it wouldn’t have to be done manually. I’m open to any thoughts or suggestions on other ways to manage this.
