macjimbo
Jul 19, 2017Aspirant
GS728TP: PoE Fault
So we had a storm and a power cut and now virtually all of my Netgear Smart switches fail to operate PoE on some or all ports. The ports all work fine for data, but most have no PoE. Looking...
JohnC_V
Jul 20, 2017NETGEAR Employee Retired
Hi macjimbo,
Welcome to the community!
It seems that you are now experiencing "OtherFault" status on your poe switch. Unfortunately, we still doesn't have any fix for this issue. You may open a case / chat online on NETGEAR support and please let them know the status of your switch. Also be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
Please also check our warranty policy here.
macjimbo
Jul 20, 2017Aspirant
Thank you John
Unfortunately, I can't figure out how to start an online chat. All paths seem to lead to premium support options.
Please can you let me know how I do this?
Thank you
- JohnC_VJul 25, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread if you were able to set a replacement on this device and everything works ok now.
- macjimboJul 27, 2017Aspirant
Many thanks for the follow up
Onice I figured out how to get hold of a human at Netgear, he was more than helpful on the phone and arranged replacements for all of the failed/defective switches.
Excellent customer service, marred only by the difficulty in finding a phone number on the website.
Thanks again
- JohnC_VJul 28, 2017NETGEAR Employee Retired
Thanks for your update! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
