macjimbo
Jul 19, 2017Aspirant
GS728TP: PoE Fault
So we had a storm and a power cut and now virtually all of my Netgear Smart switches fail to operate PoE on some or all ports. The ports all work fine for data, but most have no PoE. Looking...
macjimbo
Jul 27, 2017Aspirant
Many thanks for the follow up
Onice I figured out how to get hold of a human at Netgear, he was more than helpful on the phone and arranged replacements for all of the failed/defective switches.
Excellent customer service, marred only by the difficulty in finding a phone number on the website.
Thanks again
JohnC_V
Jul 28, 2017NETGEAR Employee Retired
Thanks for your update! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
