luas's avatar
luas
Tutor
Dec 13, 2018
GS748T Issue with DHCP filtering
Hi,
I have an issue with a freshly configured GS748Tv4, where DHCP filtering is not working as expected.
I enabled DHCP filtering and set port 50 as trusted, all other ports as untrusted. But when I remove the uplink from port 50 and plug it into a different port, I will still receive DHCP offers.
Any ideas what could be the cause?
Firmware is up-to-date (5.4.2.30)
  • Hi luas,
    Let us isolate the problem.  Kindly answer the questions below:
    a. Was DHCP Filtering on the GS748Tv4 switch working before?
    b. Is the DHCP server connected directly to port 50 (uplink port)?
    c. How is everything connected?  It would be best if you post an image or screenshot of your detailed network setup.
    d. Have you tried to reboot the GS748Tv4 switch?  If not yet, kindly try it then check if the same problem will occur.
    e. Have you just newly updated the firmware of the GS748Tv4 switch to v5.4.2.30?  If yes, I suggest you to perform a factory reset then reconfigure the settings from scratch and check if the same problem will occur.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi luas,
    DaneA
    • luas's avatar
      luas
      Tutor
      Hi,
      thanks for your reply!
      Right now, I can't reproduce it. I guess it was some issue with the notebook caching the address.
ProSupport for Business
