PapaPeteH
May 17, 2023Guide
GS748Tv5 - Update FW using Web interface, NOT Smart Control Center!
Ignoring the pain of discovering HOW to do a firmware update, I have just learned that the only reliable update method is using the Web UI File Manager... at least for my #GS748Tv5 that used to be ru...
PapaPeteH
May 19, 2023Guide
schumaku wrote:There is a lot of legacy with these switches, in wording and the utility.
To start with the Smart Control Center (SCC) - which is EoL for a longer time already. SCC does not know about the two firmware flash partitions. As such, it assumes there is only one, and only the first flash partition, and it's set to be active (to boot from).
schumaku, I suspect you are running on old memories. Here's a bit more detail of my process and findings:
A good reference worth reading is GS716Tv3, GS724v4, and GS748Tv5 Software Administration Manual (of course), keep in mind it's dated September 2013 at time of product release without any major changes on the operations and administration. The File Management section does explain about the File Management, HTTP File Download ....
That's WONDERFUL... for those who already know the answer!
Here's a few of the challenges involved for those of us who don't already know:
- Everywhere online involving version numbers and downloads, refers to Firmware versions and Firmware installation. NOT "image" or "software image."
- The user is not told how to accomplish updating firmware anywhere in the download or the downloaded files. Instead, we're told to read the fine User Manual.
- I searched the Software Administration Manual to find the needed info. A search for "firmware" quickly leads to the following info:
- p 11: "...the Smart Control Center provides several utilities to help you maintain the NETGEAR switches on your network, such as...firmware upgrade"
- (pp 68, 120, 287) Irrelevant discussions of LLDP, Multicast Router VLAN config, Regulatory Compliance
- p 284: A table claiming the system supports one firmware upgrade "set"
- That's IT. So, of course I headed to the SCC. I knew it was outdated but figured that was my only available path for this "current" yet less-than-latest device.
- I searched Netgear Support. That gives https://www.netgear.com/support/product/gs748tv5
- "Top support article" -- "How do I use the Smart Control Center to upgrade the firmware of a smart switch?"
- This (kb #24699) contains outdated instructions yet they did function...except the final instruction says "The firmware is downloaded to the smart switch and the smart switch restarts."
- It didn't restart. And the version number was incorrect.
Here's a screen shot of the download UI in SCC for the GS748T:
SCC gave me the option of which partition to use. I selected the second partition, which was correctly used.
Sure looks like it ought to work π .But it did not.
SCC claimed to have successfully "downloaded" the file. As I discovered later, once I found the File Manager, I saw that it did download something into the secondary image storage area. However, the result was an incorrect version number. (Doing the same thing later from the switch web interface, with the exact same file, didn't have that error π)
Definitions for other newbies who find this thread:
- In the Admin Manual "Firmware" is mostly called: "archive", "software image" or just "image." This is not explained anywhere.
- "Reboot" is sometimes called "reset." (Ignoring section headers and the "Reset menu" name, the manual uses "reboot" 21 times, and "reset" 3 times. The other 32 uses of "reset" refer to counter resets or reset to factory defaults. )
- "Download" and "Upload" are from the switch perspective, NOT the user's device/system perspective. (Yes, you are doing this, but someone decided you need to become the switch to understand this π)
PS: Netgear could easily clear this up:
1. In the Admin Manual, at the beginning of the Maintenance chapter, introduce the unique file types referenced. For example:
Switch maintenance beyond resets involves file-related functions for several types of files. Jargon specific to this switch includes:
- Switch firmware: stored in an "image" storage area, also called an "Archive." Firmware is normally transferred in a *.stk file.
- Switch configuration details, transferred in a (user editable) text file, with *.cfg extension.
- SSL certs using *.PEM format
- Other file formats noted below.
2. Correct the Admin manual and Support pages on Firmware to no longer reference the SCC utility, but instead to reference the Maintenance portion of the manual, and "Archive"-related functions.
schumaku
May 19, 2023Guru - Experienced User
Afraid, I have to destroy some simplified models.
Firmware images can be delivered as .stk, .img, .image, .bix, and many more different extensions. Even interesting designations like xx123abc_Vn.n.n.n-runtime.image exist. Even more naming conventions some into my mind when it comes to routers and the likes. In many aspects, this depends on the chip set manufacturer, the development kit implementation, or the eruptions on the sun when the things were created.
Said this, the interesting upload and download discussion I had for the first time as a young student, working on physics projects some 40+ years ago. Initially, I never became warm with the idea. But while becoming older, based on growing of knowledge in physics, mechanics, dynamics, ... lead to the study of an old book. it's not about right or wrong. It's all about philosophies and imagination.
Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.
E. Hamilton Lee, 1949
- PapaPeteHMay 24, 2023Guide
And, perspective π
(Rather helpful when learning about relativity, let alone orbitals and quantum physics. OT I know -- have you looked at recent Wigner's (Friend in a box) experiment updates? Fascinating stuff π ) ... and now back to our normally scheduled Network Programming...
