EFaden's avatar
EFaden
GS752TP - Slow Web Interface
Anyone else have this problem? The web interface is so slow as to almost become unusable. It loads the background then just hangs for a good 20 to 30 seconds. Sometimes it loads the buttons... sometimes it just sits with a blank background. When I do manage to get into the interface clicking on a button sometimes loads the data... sometimes it just sits there and I have to close the browser and start again? Anyone have suggestions? It is running the latest (also the initial firmware).
-Eric
  • I've been having this same problem for some time now.
    As a "fix" \ "workaround" \ "bodge" I've used Firefox Portable 3.5.6 to update changes to VLAN\LAG settings.
    This really isn't ideal, but does work.
    /pokes Netgear with a big pointy stick!
  • I'm glad, that i don't need to install windows 98 with ie5 to configure my switch
  • Thanks for this tip. At last I can configure my three new GS748TS switches.
    With a five-year-old browser!? This is very poor, NetGear.
    • Tyson_'s avatar
      Tyson_
      I as well am experiencing this.  THe web interface is painfully slow.  Clicking on anything results in a 5-10 second wait, every time.  It's exhausting.  Yes, I've tried all the browsers.  Yes the problem exists with all of them.  With every firmware upgrade I hope that it will be fixed.  Alas, still, even with the latest, still slow.  I really don't fancy spinning up an XP machine just to manage my router...
      • spizzy74's avatar
        spizzy74
        I also need to be able to configure LAG but cannot using any browser.
        This is a real issue.
        Can netgear tell me exactly what browser and version is supported since none of the big 4 browsers arent?
ProSupport for Business
