tigo13
Mar 01, 2023Star
MS510TXM, fan status, operating temperature!
I'm a bit confused on whether I should do something regarding the ventilation around the switch or to replace the fans inside the switch, or to do nothing at all. The temperature readings for the...
schumaku
Mar 02, 2023Guru - Experienced User
tigo13 wrote:
..., as the manual states that the switch's operating temperature is 0-50'C. ..
The specs indicate the supported environment temperature, the room where the device is operated. 10 Gb switches are hot while operations.
tigo13
Mar 02, 2023Star
Glad to hear. Can now forget about it, and not be concerned. The environment is general room temperature.
cheers for the reply.
