Victor-R
Apr 18, 2018Aspirant
XS728T - Archive/Config file upload: How to find file path for USB drive connected to front panel?
XS728T ProSAFE 28-Port 10-Gigabit L2+ Smart Switch Software Version: 6.5.1.30 Boot Version: 1.0.0.0 Our XS728T is being replaced under warranty. I want to export the Archive/Text config files, ...
- Apr 19, 2018
Thanks, I ended up downloading the file via the GUI (with help from Netgear Chat Support)
DaneA
Apr 19, 2018NETGEAR Employee Retired
Hi Victor-R,
As per page 336 of the XS728T user manual here, in #7 under the section "Upload a File From the Switch to a USB Device," it says to leave the File Path field blank to save the file to the root USB directory. Kindly try to leave the File Path field blank and on the USB File field, be sure to enter a name.
DaneA
NETGEAR Community Team
- Victor-RApr 19, 2018Aspirant
