Victor-R's avatar
Victor-R
XS728T - Archive/Config file upload: How to find file path for USB drive connected to front panel?
XS728T ProSAFE 28-Port 10-Gigabit L2+ Smart Switch Software Version: 6.5.1.30 Boot Version: 1.0.0.0   Our XS728T is being replaced under warranty. I want to export the Archive/Text config files, ...
  • Victor-R's avatar
    Victor-R
    Apr 19, 2018
    Thanks, I ended up downloading the file via the GUI (with help from Netgear Chat Support)
ProSupport for Business
