Pank007
Apr 07, 2018Aspirant
GS108P setting VLAN
Hi, I have a GS108P unmanaged switch and was looking through the documentation. I noticed that there is a network diagram in the documentation that shows the switch can support 2 Vlan. Could some...
- Apr 09, 2018
Welcome to the community!
I agree that the diagram depicted in the GS108P Data Sheet is misleading. However, what it really denotes is the capability of the GS108P switch to power up access points (such as WNDAP330 & WG103 shown in the diagram) that supports PoE which is connected by the red lines and at the same time you can connect other networking devices (such as PCs) which is indicated by the blue lines that describes that the GS108P extends the local network.
It is not possible to configure VLANs in the GS108P switch since its an unmanaged switch.
Just to add, the GS108P switch is already EoL ( End-of-Life). I have already sent a report about the GS108P Data Sheet to be corrected.
DaneANETGEAR Community Team
DaneA
Apr 09, 2018NETGEAR Employee Retired
DaneA
- DaneAApr 15, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- Pank007Apr 15, 2018AspirantThanks for the reasponses.
Hopefully NETGEAR will correct the diagram in the documentation.
