deffi
Sep 29, 2017Aspirant
No Ethernet Connection after Connect with GS105 Switch
Hi I am a newbie concerning switches and have the following problem: I have connected my GS105v4 ProSafe Switch with a patch cable to the Fritzbox (from port1 the Fritzbox to port 1 of the switc...
- Oct 01, 2017
Hi,
thanks for answering, but the problem has been solved in the meantime. But anyway I will answer your questions, maybe it´s a help for somebody else:
your questions 1 and 2:) If the Pc was connected via switch to the fritzbox (7390), I couldn´t ping the fritzbox. PC and switch were not visible/existing in the network.
3.) Fritzbox 7390 modem/router combination
4.) Yes direct connection to the fritzbox was no problem.
The solution:
At the next day/overnight everything works fine without doining anything. The only thing what happens over night is the daily provider forced disconnection of the my fritzbox. And we had a short blackout in the night, so all devices have been dead for a few minutes and restarted automaticly.Stefan
deffi
Oct 01, 2017Aspirant
Hi,
The solution:
Stefan
