Staggs0226
Oct 13, 2025Aspirant
No internet after switch is plugged in
I have a GS305v3 unmanaged switch that I just bought and attempted to use. It is connected to my internet via cat6 cable that I ran from my office in my house where my router/modem is located, to my ...
Staggs0226
Oct 14, 2025Aspirant
I will try this when I get back home this evening. If the switch still does not work, am I looking at a bad switch?
Oct 14, 2025Guru - Experienced User
Staggs0226 wrote:If the switch still does not work, am I looking at a bad switch?
Either a bad switch, or an incompatibility between the switch and the Eero multigig LAN ports.
Try both the 2.5 and the 10gb ports on the eero, as they might behave differently.
