amheck
Aug 28, 2018Tutor
RMA replacement DOA - nobody will reply to open Support case #30006330
Hi had a GS305 switch stop working. I did a RMA replacement. The new switch arrived and the power light just slowly blinks and I can't any traffic to pass through. Netgear isn't responding to the ...
- Aug 29, 2018
Hello amheck,
I was able to locate your case. I have reached out to our customer care team and provided them with the additional information posted here. They will assist me in getting a representative to review the next actions for your case and reach back out to you promptly.
Kind regards,
Christine
ChristineT
Aug 29, 2018NETGEAR Employee Retired
Hello amheck,
Let me check into this and see what I can do to get this case back on track!
Thanks, schumaku for the shout out. :-)
Best,
Christine
- amheckAug 29, 2018Tutor
thanks to you both.
FYI, I'm not sure of the exact case number. Under "My Support" on the main page, its listed as Case #30006330 but when you click on that and go into the text of the ticket, its listed as Case #00905238
I'm not sure if one is the ticket and one is the case, but hopefully you can find it
- ChristineTAug 29, 2018NETGEAR Employee Retired
Hello amheck,
Kind regards,
Christine
- amheckAug 30, 2018Tutor
Received a call from Customer Care yesterday and we have an advance replacement coming out in the mail. thank you for your help!
