Squiddley
Feb 02, 2019Initiate
Second GS205 connected to router not sharing internet
Hello community.... I cannot find specific answers to my problem amd appreciate help.
I have used one of these switches for 18months without issue. Connected to my R8000 router and the. To the peripherals. Now I bought another one, and connected a working LAN cable to the switch, but devices connected to the switch have no network. I have interchanged he switches and the new one works with the old setup.
My last resort will be a new flat cable, but the one I have works fine when connecting the router to the laptop directly... disconnecting that same cable from the laptop and connecting to the switch results in failure. Theres no comsistent connection light.... just a periodic flash.
Thanks in advance.
Hi Dane
Thank you for the welcome. I bought a new 10m flat cat 6 cable, which works fine with the second GS205 now. The New GS205 is now a spare for future use. The problem must have been with the old flat lan cable, though why it failed to work with a switch yet was fine directly in the laptop lan socket is beyond me.
To avoid disppointment I also bought a TP-Link SG1005D 5 port gigabit switch that works too. It also didn’t like the lan old cable, so both hardware products are fine.
My issue is now resolved, and thanks for the follow-up.
Cheers!
- DaneANETGEAR Employee Retired
Hi Squiddley,
Welcome to the community! :)
This means that the new GS205 is working.
Were you able to try another ethernet cable with the new GS205 switch? If yes, what is the result?
DaneA
NETGEAR Community Team
- SquiddleyInitiate
Hi Dane
Cheers!
