a2736's avatar
a2736
UNMANAGED SWITCHES
NEED TO REPLACE MY UNMANAGED FS108 SWITCH AS MY INTERNET SPEED HAS INCREASED TO 300 MBPS . NEED AN 8 PORT WHAT IS THE BEST CHOICE FOR REPLACEMENT (MODEL NUMBER) ?
  • a2736,
    The product of GS108v4 in United States is GS108-400NAS.  You may want to verify it with Amazon if the product code of the GS108 switch their selling is GS108-400NAS.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi a2736,
    Welcome to the community! :)
    Since your internet speed you are subscribed with has increased to 300Mbps, I think what you need is to change the firewall router that you have that supports a LAN-to-WAN throughput greater that 300Mbps.  However, if you just want to replace your old FS108 unmanaged switch with a new one, I recommend you the GS108v4.  Kindly check its specifications on the data sheet here.
    DaneA
    • a2736's avatar
      a2736
      DANE
      THANK YOU VERY MUCH FOR YOUR ADVISE . I WILL BUY GS108 AN INTALL IT. AS FAR AS THE ROUTER CONCERNED . MY ROUTER IS AN AIRPORT EXTREME AND DOES SUPPORT SPEEDS UP TO 1GB. ALSO STRANGELY ENOUGH WITH MY FS108 SWITCH I AM GETTING 300 SPEED ON ONE PORT AND LESS THAN 100 (40 TO 50 MBPS) IN THE OTHER 6 PORTS.
      • a2736's avatar
        a2736
        DANE
        ONE MORE QUESTION ON AMAZON THEY ADVERTISE THE GS108 SWITCH  AS GS108 WITHOUT THE 8v4 affix . I AM ASSUMING IS THE SAME SWITCH. PLEASE CORRECT ME IF I AM WRONG
    • DaneA's avatar
      DaneA
      a2736,
      DaneA
ProSupport for Business
