CJT-80
Nov 04, 2016Follower
Using a GS105v4 with a GS108
Hi there, I currently have a GS105 (5 port unmanaged switch) which I am very happy using, but I wondered if I want to expand my switch capacity can I use the GS105 with a GS108 (8 port unmanaged...
- Nov 07, 2016
Hi CJT-80,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Nov 07, 2016NETGEAR Employee Retired
Hi CJT-80,
Thanks,
