Daikan's avatar
Daikan
Initiate
May 08, 2019
BR500 connectivity to CenturyLink ISP
It appears that the BR500 (5.6.0.1 or previous versions) is not able to connect the internet when using a CenturyLink ISP fiber modem such as calix 716GE-I. The problem is that CenturyLink requires a LAN tag of 201 on the WAN port. The BR500 does not provide the option of changing the the LAN tag. It seems to be hard coded to the value of 2. A competitor's router provides this functionality. Using the competitor's router I can connect to the ISP and connecting the BR500 WAN port to a LAN port on the competitor's router internet connectivity can be achieve. The internet speed is affected because of limited bandwidth through the competitor's router. I don't think a VPN connection can be established in this configuration. Has others had this issue? Thoughts?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Daikan,
    Welcome to our community! :)
    Unfortunately, BR500 doesn't support VLAN tagging on the WAN Port. You may also suggest this in our Ideas Exchange for Business board so that the engineering team would consider it and include it in our next firmware release. But we cannot guarantee it :)
    JohnCarloV
    NETGEAR Community Team
  • JohnC_V's avatar
    JohnC_V
    Hi MrJoshW,
    Honest mistake :) I overlooked that on the manual.
    JohnCarloV
    • Daikan's avatar
      Daikan
      Initiate
      Yes, that what the manual says. However, it does not work. Furthermore, also on page 92 it says you can have LAN VLANs or IPTV bridge with a WAN tag, but not both. To me that is a non-starter. TP-Link, a competitor device, has WAN tagging and the ability to have LAN VLAN tagging. As a commerical wire router it seems these are desirable features.
ProSupport for Business
