Ralf_Hentschel
Mar 10, 2017Aspirant
emailing logs
I'm trying to set up E-MAil logs on the FVS338.
Years ago this already worked successfully.
E-Mail Server: securesmtp.t-online.de
Custom SMTP Port: 587
E-Mail User account from ISP: t-online
I have ticked "Login Plain" entering username and password from ISP t-online.
I have ticked "Respond to Identd from SMTP Server.
The FVS338 ist installed directly behind a FRITZBOX 7490. The fritzbox is connected to the VDSL Line.
Basically there is a DMZ between the FRITZBOX 7490 and the FVS338 but with now additional devices connected to it.
FVS338 Firmware: 3.1.1-08 (Latest version)
IP Address Fritzbox 7490: 192.168.2.1
Gateway address in FVS338: 192.168.2.1
Satic IP Address from FVS338: 192.168.2.109
LAN TCP/IP Setup: IP Address: 192.168.100.109 in FVS338
DHCP Server in FVS338 is enabled.
Using FVS338 Diagnostics, it can resolve the SMTP-server securesmtp.t-online.de.
Ping on resolved IP-Addresses is working fine.
Checking the SMTP-server login data using the FRITZBOX 7490 is successful ( I'm receiving Mails from the Push service of the Fritzbox 7490)
Checking SMTP-Server settings using Microsoft Outlook / POP3 is successful as well.
All internet applications are working excellent.
When Trying to send Logs via E-MAil (Menu: "Firewall Logs & EMail/View Log/"SendLog") , the router responds with "Connection interrupted"
No e-Mails are sent out or received by my E-Mail provider.
My Question:
What is wrong in my FVS338 Settings ?
Is there a possibility to check the communication problem of the FVS338 with the SECURSSMTP.t-online.de ? ( I do not see any log-entry in the Log data)
I would be glad if someone could help me.
Best Regards
Ralf
I think I'm right (see post above)
- Ralf_HentschelAspirant
I think I found the problem:
t-online has changed from smtp.t-online.de to securesmtp.t-online.de including SSL/TLS security.
I'm not sure if the FVS338 supports SSL/TLS encryption for E-Mails
