leinhto
Sep 05, 2016Aspirant
Cannot connect to WAC730 after factory reset
Please help. I am unable to access the AP after a factory reset. All the lights are coming on as normal. The router sees it and assigns it an IP. However, when I try to access the management page on ...
- Sep 06, 2016
Hi leinhto,
Kindly try the steps below:
1. Disconnect the WAC730 from your existing network and make sure its turned on. Get a straightened paper clip.
2. Insert the paper clip to the factory defaults hole then press and hold the factory reset button inside it for 30 seconds.
3. After 30 seconds, turn off the WAC730 while you still continue to press and hold the factory reset button. Wait for 5 seconds.
4. After 5 seconds, turn on the WAC730 switch while you still continue to press and hold the factory reset button. Wait for another 5 seconds.
5. After 5 seconds, release the paper clip from the factory reset button. Wait for the WAC730 to boot up properly.
6. Try to access the web-GUI of the WAC730.
DaneA
NETGEAR Community Team
leinhto
Sep 18, 2016Aspirant
Yes. Both are working fine now. Working on the Zyxel router VLAN. Thanks for the help.
- DaneASep 19, 2016NETGEAR Employee Retired
Hi leinhto,
You're welcome! I'm glad to know that both devices are now working fine. :)
Since your concern is now resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
