adpwl1's avatar
adpwl1
Follower
Aug 04, 2025
IOS Apple Devices Dropping
I have WAX625, WAX610, & 605.
For a number of months now, my IOS devices continue to drop their WIFI and then takes 2-5min to reconnect.  I originally had Load Balance and Remove Sticky Clients configured.  I have put everything back.
Firmware on the AP is 10.8.13.2
I am a technical guy and I feel I have tried all the other things that have been mentioned in posts that sort of sound like mine.
I think this is only happening on my 5/6ghz SSID.  I Have a SSID for 2.4 and one for 5/6.
Any suggestions?  Anyone else seeing this?  Im so frustrated that I'm looking at a different vendor for the house.
I am managing these in Insight.
  • (5) WAX630E’s here on latest firmware and same problem. Latest phones, latest iOS. Also sometimes happens with 2019 MacBook Pro intel where it grabs slower xfer speed vs. 1300mbps which it should normally.
  • Hello!
    It's frustrating when devices drop their connection, especially in a technical setup. Since you've already tried basic solutions, the issue is likely related to how iOS devices interact with your multi-AP environment. Try adjusting a few advanced settings: manually select a static non-DFS channel (like 36-48) to prevent disruptions from radar detection; temporarily disable Fast Roaming (802.11r), as it can sometimes cause stability issues with certain clients; and lower the 5/6 GHz transmit power to encourage better roaming between your access points. Additionally, you may want to check your Insight logs for clues and test disabling the "Private Wi-Fi Address" on one of your iOS devices.
  • Pramendra's avatar
    Pramendra
    NETGEAR Expert
    Hi adpwl1​
    Request you to upgrade to the latest firmware released on Friday and let us know if you see an improvement.
    Warm Regards,
    Pramendra Singh
    NETGEAR NFB Wireless Team
    • xjrguy's avatar
      xjrguy
      Star
      Massive improvement across the board with the latest firmware. Excellent progress, thank you!
ProSupport for Business
