todanielchow
Dec 16, 2015Aspirant
multiple WNDAP360 in one room, 100+ devices
Hello everyone, we have a WC7520 controller with about 34 WNDAP360 to cover our entire secondary school campus. Its working quite well. But some of our spaces are starting to assemble 90+ students in...
- Dec 17, 2015
Hi todanielchow,
Welcome to the community! :)
Regarding your concerns, I think you will need to configure Load Balancing and Basic Local MAC Authentication on the WC7520. Kindly read pages 107-108 about Load Balancing and pages 118-119 about Basic Local MAC Authentication on the WC7520 reference manual here.
DaneA
NETGEAR Community Team
DaneA
Dec 17, 2015NETGEAR Employee Retired
Hi todanielchow,
DaneA
todanielchow
Dec 18, 2015Aspirant
Thanks Dane!
So when I purchased the system a couple of years ago, I worked with Mark E. and Keith N., they mentioned that these WNDAP360 access points are good for about 40 simultaneous connections each. An email I was sent regarding this question mentioned that the WNDAP360's are good for about 128 connections... which one do I go with?
I will try the load balancing feature, but do I need to add more access points to the same room when trying to connect 90-100+ devices in that room?
Thank you for the response!
- JohnRoDec 18, 2015NETGEAR Employee Retired
Hello todanielchow,
Yes, the WNDAP360 has support for up to 128 users with controller management. Now, when using load balancing you can specify the maximum number of devices that can associate to the access point. If the maximum number has been reached, they will be pushed to the closest access point. The decision to add more APs will come down to how much load you want a single AP to handle. If you want a better performance, you will have to set the AP to a lower number and add another access point.
I hope the information I provided will help you if you have more questions let us know.
Thanks,
