jurek224466's avatar
Feb 20, 2022
Netgear wax218- 2.4GHz radio random disabling
I have a problem with the Netgear WAX218 router. After switching the channel width to 20MHz / 40MHz, my radio fades to 2.4GHz. When I have the 40MHz channel set my 2.4GHz radio turns off randomly but works fine after a while. The router has the latest version of the system. I added the link https://drive.google.com/drive/folders/1KX53Wtq5KmL_5ByiGRmoRHUyWrxszP7o?usp=sharing to the screenshots of my access point settings. Does anyone have an idea for this? I will be grateful for the answers.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    jurek224466,
    Was everything working fine before?
    Let us try this. Kindly disable 11ax mode then check if the same problem will occur.
    DaneA
    NETGEAR Community Team
    • Hi. I have had such problems for some time. On the 40MHz channel it works fine after turning off the 11ax mode. Now I will test it on the 20MHz / 40MHz setting. I will let you know what and how.
      • jurek224466's avatar
        jurek224466
        Guide
        Niestety w trybie 20MHz / 40MHz radio 2.4GHz nie działa z wyłączonym trybem 802.11ax. Zauważyłem również, że czasami prędkość sieci LAN wynosi 100 Mb / s zamiast 1 Gb. Z reguły jest to 1Gb.
  • DaneA's avatar
    DaneA
    jurek224466,
    Let us try this.  Perform a factory reset on your WAX218 then reconfigure the settings from scratch.  Observe if the same issue will occur.
    DaneA
    • I have already tried restoring the firmware to the factory settings and it did not work. I was also doing a downgrade and it was useless.
      • DaneA's avatar
        DaneA
        jurek224466,
        This needs further investigation.  I suggest you to open a support ticket with NETGEAR Support here at anytime.  Kindly state that status of your WAX218 and the troubleshooting steps done to isolate the problem as well as you can include a link to this thread.
        DaneA
    I think I found what's causing the problem. Try to set the static channel to 2.4GHz in your copy, for example on channel 6. I checked it on two devices. One is mine and the other is new and the web is visible. Let me know what the situation is like for you.
ProSupport for Business
